Slight miss.
Old Dec 17, 2005 | 09:51 PM
highline95jl's Avatar
highline95jl
Default Slight miss.
My 95 Neon Highline 5 Speed SOHC with CAI has a slight miss to it when Idiling, what could it be. Thanks
Old Dec 17, 2005 | 10:23 PM
whyte69's Avatar
whyte69
Default RE: Slight miss.
all I can think of is the usual: Spark plugs, wires, fuel injector cleaner, time for a filter change?, any thrown engine codes? Does the length of time its been running matter? Any work done to it lately? Has it just started doing this recently? Does anything make it better/worse?
Old Dec 17, 2005 | 10:47 PM
Gary Howell's Avatar
Gary Howell
The wires on Neons, if stock are notorious for going bad. Pick up a set of Crane wires. We have htem for both DOHC and SOHC
Old Dec 17, 2005 | 11:22 PM
highline95jl
The car does have new spark plugs, the wires are the factory ones from 95. The filter has been changed and no codes. After idling for 40 min it starts up. The mis goes away when the car is moving. No work done to it lately besides new brakes. It gets better when car is not moving.
Old Dec 17, 2005 | 11:23 PM
highline95jl
Oh car does have a bad valve cover gasket.
Old Dec 18, 2005 | 01:33 PM
Gary Howell
Change out the 10 year old factory wires with some Crane wires.
Old Dec 18, 2005 | 05:30 PM
whyte69's Avatar
whyte69
what kind of plugs did you use? Are they by any chance platinum?
Old Dec 19, 2005 | 01:08 AM
LowSlowNeon's Avatar
LowSlowNeon
Thats a good point whyte. Some NGK V-Powers would be a good choice if you need new ones.
Old Dec 19, 2005 | 03:36 PM
beerplease's Avatar
beerplease
if u got a 95 like me and you have no codes and recent tune up, check all your vacum lines for cracks and disconnections,that can cause your problem and cheap easy and likely repair, a cracked line should but doesn't alway's give a trouble code. try it and let us know.
