high idle
Old Oct 11, 2006 | 05:53 AM
  #41
FyreDaug's Avatar
FyreDaug
Default RE: high idle
ORIGINAL: HabitatHxC
Oh ya i forgot that i had this problem at one time... it was really simple to fix too... HOPEFULLY IT WILL WORK FOR YOU! Ok so we were pouring rice into the intake... Because it acts like a glass bead, and breaks down the solid carbon on the top of the pistons and blows out the exhaust. Well After doing this... my car idled high... REALLY high... So we pulled the throttle body off, cleaned it up real fancy. Put her back on... Still the same... So my friend had the bright idea... Trying to push the butterfly CLOSED. Then he choked it out, Wiggled the throttle cables, (pulling them as if you were CLOSING the TB) And VWOLA! The idle died back down to normal and i strolled along on my merry way! We think by pulling the throttle cables too hard they got stuck open a little and we didnt notice. So HOPEFULLY this works! give it a shot... its free!
Old Oct 11, 2006 | 07:03 AM
  #42
racerx55's Avatar
racerx55
rice huh..
Old Oct 11, 2006 | 07:21 AM
  #43
95neonriceeater's Avatar
95neonriceeater
i prefer to eat it
not stick it in my engine...
Old Oct 11, 2006 | 06:08 PM
  #44
HabitatHxC's Avatar
HabitatHxC
It really works, many old school guys doit because it crushes and gets blown out the exhaust, it takes the carbon with it! its kinda like the solid form of sea foam but it takes bigger chunks of carbon out!
Old Oct 11, 2006 | 06:59 PM
  #45
rrwertz's Avatar
rrwertz
mopar sells a combustion chamber cleaner.
you can also use seafoam.
neither require putting rice into your engine
Old Oct 11, 2006 | 08:07 PM
  #46
FyreDaug's Avatar
FyreDaug
Well ill still have to see what else I can do, its been bloody cold and I havent had access to my garage for a few days. One of these days ill get it in there and lift it up to check the o2's. Both of them? Can I spray something on em too?
