lubricating gauges
Old Jan 8, 2006 | 06:54 PM
davbell22602's Avatar
davbell22602
Default lubricating gauges
What the easiest way to lubricate my speedometer gauge? What part of the dash has to come off to lubricate the speedometer? How do you take the dash apart to get to it?
Old Jan 8, 2006 | 09:36 PM
mr340's Avatar
mr340
Muscle Car Moderator
Default RE: lubricating gauges
Ummm, I don't think you can lubricate an electronic gauge.....
Old Jan 8, 2006 | 09:44 PM
davbell22602
my mechanic said you still have to use some lubrication on it even though its electronic. its on a 96 dodge neon highliner 4 door sedan.
Old Jan 9, 2006 | 12:12 AM
casper's Avatar
casper
If its not making noise, leave it alone, there really is no need to lubricate it. If you do use a dry lubricant with graphite.
Old Jan 9, 2006 | 12:50 PM
davbell22602
but my speedometer needle sticks and it starts working after running the heater for awhile.
Old Jan 9, 2006 | 07:27 PM
casper's Avatar
casper
ORIGINAL: davbell22602
Just use a dry lube.
Old Jan 9, 2006 | 07:41 PM
davbell22602
what about no contact spray?
Old Jan 9, 2006 | 07:47 PM
casper's Avatar
casper
Its oily and will make a mess of your gauges.
Old Jan 10, 2006 | 02:34 AM
RadarLove's Avatar
RadarLove
Using a guage overlay perchance?
Try rubber cement or double-sided scotch tape on the back of the overlay...
Best of luck!
Old Jan 10, 2006 | 02:45 PM
mattdog's Avatar
mattdog
The gauge needle motors consist of a magnet which sits in thick oil and 2 magnetic coils that wrap around the magnet. IMO the purpose of this oil is to help maintain smooth steady needle movement while lubricating the parts. Unless the needle motors have been upside down the oil will not come out. The only real way to get the oil back in there is to put a few drops around the shaft and hope they make it down in there. I haven't bothered to try this, I just throw out the defective motors when i'm building gauges.
