help converting an automatic to standard?
neongoodies.com has a solid bobble that has adjustment for preload, and if your car does not have a bracket on the k member he also sells the bracket to weld on...
ORIGINAL: casper
Its all swap one to the other. You will need a MTX PCM though because the ATX PCM is tuned a little different and has trans sensor pickups that the MTX does not have.
I wanna know where you are getting a Trans, pedals, cables, shifter, linkages, and a PCM for $75!!! Your looking at probally more like $250-$300 for everything.
notallhere Date 1/20/2006 8:36:10 PM
I'm getting ready to do the same thing myself, going to the junk yard and pulling all the components comp and all
should not be a problem as all the mounting holes ant stuff is already there.
Gonna rebuild the tranny first and change the diff. and go wiht a largerer clutch as im lookin for off line torque.
Arond here they told me 75.00 for everything so hey why not!
I think 250-300 is still a little low if you can find the oparts.
Oh, haha. Eraly morning for me. Picking up my rims. Isnt there a pull it junk yard down by rockford? People were talking about it for the neon2k8?
it cost me 150 for trany with fly wheel and mount junkyard
100 for the shifter, links,clutch cable and pedals junkyard
150 for new clutchautozone
55 for new right half autozone
20 for ecu96 mtxno other one will wrk ebay
475 total
475 total
ok i have a 03 neon SXT i am planning to put a Srt 4 engine and stick tranny into it. what i am wondering what am i going to need besides to obvious to do this... also any ideas on what this could run me? and to state the obvious this is going to be my first time doing this.
your talking about a rediculous amount of work
first, if you live in cali, and your car was bought in cali as an automatic, the swap is illegal, all automatic neons sold in cali that were sohc engines, are TLEV vehicles and it is illegal to swap to any other engine or tranny, trust me i dropped $3000 into a race prepped tranny just to not be able to smog it again because of swapping computers
since you have a second gen neon, it will be a little easier then a first gen, but its going to cost in the $4000 range for a sound motor and tranny, and dont even attempt this unless you have someone that can help with the wiring
