Help with new Gauge face
Old Jan 25, 2006 | 05:58 AM
DodgePerformance's Avatar
DodgePerformance
Default Help with new Gauge face
Ok so I got this Indigo lights, and installed them today. Well I left the old face plate on under them, because I thought I was supposed to. Well the needles don't move, they do kinda, but I have to push on the dash to get them to where they are supposed to be. My speedometer does not move at all, they are lined up, and the needles are on good. My friend that helped me, said that the new face was bowed when it came in the box, and thats the prob that they are not flat yet. Once they sit in there, and flaten out they will start moving. It's all done correctly, just the needles don't move by themselves. Any ideas?
Old Jan 25, 2006 | 08:48 PM
casper's Avatar
casper
Default RE: Help with new Gauge face
You are gonna need to take it back apart and use some type of glue on the back of the faces. I used elmers water soluble glue in case I wanted to take them back off without ruining my stocks. You can use any thin glue though.
Old Jan 25, 2006 | 08:55 PM
DodgePerformance
Any other ways??? I'm not for the glue idea.
Old Jan 25, 2006 | 10:02 PM
casper's Avatar
casper
Not that I know of, I have had mine on for almost 2 years now with elmers glue and everything works fine. Thats why I used elmers, it comes off with a hot wash cloth.
Old Jan 26, 2006 | 06:04 AM
DodgePerformance
Do you think overtime it will flatten out? They are starting to work...
Old Jan 27, 2006 | 12:07 AM
notallhere's Avatar
notallhere
I had the same problem used double backed tape worked great!
Old Jan 27, 2006 | 05:45 AM
DodgePerformance
Double sided?? Won't that create a space between the new and old though??? I was thinking of taping the corners down, becuase when I push both corners the gauges move fine.
Old Jan 27, 2006 | 07:41 PM
casper's Avatar
casper
You can do it however you want, but you need something to hold the faces down. There is double sided tape that is very thin. The stuff with foam in the middle will not work. There is very little clearance between the needles and face as you have figured out.
Old Jan 28, 2006 | 08:30 AM
DodgePerformance
ORIGINAL: casper
Yeah for sure... So I will try the tape on the corners first, then go from there. Thx guys for all the help
