oil leak
Old Feb 22, 2006 | 01:18 PM
casper's Avatar
casper
Default RE: oil leak
ORIGINAL: dont33zel
what color is the coolant usaully suppose to be...mine i look at it once it was like yellowish green...but i havent looked at it lately....or the oil....
The coolant should be see-thru, it should not be milky. The oil should look like oil, not chocolate milk. Maybe you should check them.
Old Feb 23, 2006 | 05:23 PM
dont33zel's Avatar
dont33zel
ill check it wen i get home today...the last time in looked it was like a neon green couldnt remember if i could see through it...
Old Feb 24, 2006 | 01:20 AM
casper's Avatar
casper
If the head gasket is bad, you should be low on oil or coolant and they should look like ****.
Old Feb 24, 2006 | 12:41 PM
dont33zel's Avatar
dont33zel
my coolant is low as ****...got low quick...what else would determine if its the gasket....
Old Mar 2, 2006 | 01:56 PM
dont33zel's Avatar
dont33zel
i opened the coolent cap when the car was running but i wasnt boilin or anything it was fine...i heard that a blown head gasket would make the car over heat...but mine doesnt over heat...still havent really had time to look at the car to see whats going on with it...i might have time today...just really need help on what it could be... any ideas...just give me a list and i will look for it today...
still leaks under the car but only wen runnin stops after a lil bit.... help!!!
