Throttle body swap
Old Feb 23, 2006 | 08:38 PM
highline95jl's Avatar
highline95jl
Default Throttle body swap
Ok gang my buddy has a 2.4L stratus and I was curios as to how big the bore is on the 2.4L DOHC compaired to the 2.0 SOHC and would that work on the Neon. What kind of gains would I get from that if the swap was doable at all.
Thanks guys.
Old Feb 24, 2006 | 12:20 AM
casper's Avatar
casper
Default RE: Throttle body swap
.4L, lol. Its not so much its that better of a motor, you can just do a lot more with it.
Old Feb 24, 2006 | 02:28 AM
whyte69's Avatar
whyte69
The SOHC Stratus has a bore width of 52mm, which is already larger than the 48mm in the Neon, but I'm not sure if you would be able to swap them directly. Your best bet would be to compare them. Even if they're the same, I would keep the sensors from the Neon on there to make sure that everything goes over without a hitch. The Neon throttle body will accept a bore of approximately 55mm while I've seen a Stratus with a bore of 65mm, which makes me think that they might not be compatible. You'd probably be better off to have your current throttle body bored out to 55mm instead of guessing.
Old Feb 26, 2006 | 02:38 PM
RadarLove's Avatar
RadarLove
The MTX Neon's TB necks down to 49mm (venturi shape). The ATX Neon TB is 52mm, same as the 2.4L Stratus. 52mm is plenty for most people, not that 55mm or even 60mm is going to hurt anywhere in the power band (doesn't help either...), dyno proven. When going to a larger TB, you can squeeze out an extra pony or two by making sure the TB and intake mani are port matched.
Best of luck!
Old Feb 28, 2006 | 02:34 PM
TiMMaYxBoY's Avatar
TiMMaYxBoY
Go pick up a automatic neon throttle body I heard there either 50mm or 60mm one of them but act as performance for the SOHC
Old Feb 28, 2006 | 02:38 PM
casper's Avatar
casper
ORIGINAL: TiMMaYxBoY
52mm, there are 55mm and 60mm performance ones out there.
Old Feb 28, 2006 | 04:35 PM
TiMMaYxBoY's Avatar
TiMMaYxBoY
o0o still good for the rpice.
Old Mar 3, 2006 | 12:54 AM
SCCA B8's Avatar
SCCA B8
so a 60mm would b too large for an auto sohc?
Old Mar 3, 2006 | 05:38 AM
FuzzRacer's Avatar
FuzzRacer
currently on ebay there are one or two jeep throttle bodies for auction both are 60's and will need some mods to make it work
