help me on this code p0101
Old Mar 16, 2006 | 01:11 PM
streetbikr600's Avatar
streetbikr600
Default RE: help me on this code p0101
will the car run any different if i plug the hole up..
ORIGINAL: RadarLove
The Mopar PCM is 50-state legal, not that it's easily identifiable unless you put the included stickers on it. You don't have to buy block-off plates. You can use a coin (nickel, dime, whatever fits) on any one of the joint locations, head is probably the easiest. You'll pass a visual. I don't recall even California doing anything that would verify the operation of the EGR. A scan for codes on the Mopar PCM sure isn't going to show them anything...
Old Mar 21, 2006 | 01:25 PM
streetbikr600
it sounds like the mopar pcm is the way to go....will it make a difference because i already put my mods on the car
Old Mar 23, 2006 | 01:16 PM
streetbikr600
would it be hard to mess around with that egr
