help me on this code p0101
my check engine light comes on i beleive thats wat the code is or it could be p0110 any ways i used the obd11 reader at auto zone and it say insuffient flow to egr now my gas milage is **** poor but i notice no performance loss. can some one help me out please........o the dude at atuo zone said that it might be a cloged diafram in the egr....
Odd... 1st gens should only have a P0112 or P0113 for an air intake fault. Is the CEL on? Does it show a code 23 using the key method? The EGR 4-digit codes would be P0401 or P0403 (code 32 using the key method).
"Circuit" is just a term for a particular section of electrical parts. The IAT circuit would include the IAT sensor and wiring, etc.
I'd double check that code before replacing parts...
Best of luck!
Best of luck!
o the code is p0401 thats wat it is it say insuffeict flow to egr....now can some one please help me it seems to come on after i put gas in it or after about every 200 miles then i clear it. then it comes back on about 200 miles later. some on please help me
The EGR system typically only functions during freeway driving, that may be how you're going so long before getting it back on.
You can find the EGR fairly easily. Under the hood, toward the driver's side, looks like a UFO... There's one pipe that connects to the head, and another to the intake manifold. You should be able to remove the assembly with hand tools, I think I had to take the TB off to get to it (years ago, when I still had one...). You can try spraying in a bunch of carb cleaner, see if it's just gumming up (very possible) and reinstall it. If the CEL comes back on, you'll probably want to replace it. You should only need to replace the valve portion though, since you aren't getting the code for the solenoid (P0403).
If you want, you can get a Mopar (or AFX) PCM, which will allow you to block off the system and never get the CEL for that again... That's what I did when my EGR started acting up.
Trending Topics
The Mopar PCM is 50-state legal, not that it's easily identifiable unless you put the included stickers on it. You don't have to buy block-off plates. You can use a coin (nickel, dime, whatever fits) on any one of the joint locations, head is probably the easiest. You'll pass a visual. I don't recall even California doing anything that would verify the operation of the EGR. A scan for codes on the Mopar PCM sure isn't going to show them anything...
the light jsut came on agian when i got off the freeway this thing is pissing me off its annoying..so u say if i get the mopar pcm the code wont show up...sweet.....
