Help! Starter changed, still won't work!
RE: Help! Starter changed, still won't work!
okay heres the deal..my 97 dohc was sitting there for the past 3 yrs..finally decided to fix it...(timming belt blow so i had valve problems) fix that already. so okay im putting it back togother right when i was ready to get that baby started it didnt start..sure enough it was starter...replaced that checked battery wires, ground wires, everything.....then found a fuel pump problem.. replaced that..now when im about to start it up, a sort of back firing pop happens. could it be that my dohc isint timed right? more battery power?<--new batt..can anyone help???plz
Hi All new to the forum.......last week went through a big puddle ended up get water in the oil pan a cylinders etc fixed all that now wont start starter probably shot clicks but wont spin over.....replaced the starter have same problem can anyone help
I have a neighbor with same problem different car. Sucked water into the intake & pretty sure the engine. My co-worker/mechanic said to Take out the plugs try starting the engine, it is to try to get the water to shoot out. If that works then put the plugs in & see what happens. Worse case you may have bent rods or valves.
