Spark plug broke in unusual place PLEASE HELP!!!
Old Sep 17, 2006 | 05:20 PM
iravven's Avatar
iravven
Default Spark plug broke in unusual place PLEASE HELP!!!
HI, im new to this forum due to the fact that i just recently purchased my sisters 1997 SOHC neon from her, two of the spark plug leads had oil on the bottom of them and after reading on here about the seals going bad to removed the valve cover in order to replace them. while i was at it, i was planning on putting new spark plugs in the car. and while i was removing one of them it snapped but in an extremely unusuall place, i really dont want to have to pull the head so any advice would be extremely helpful. if my only opetion is to remove the head could someone please give me some direction in what that entails and how to go about it. thank you and i hope to hear some replys. here is a picture of where the plug broke, its not the porceline(sp?) its almost as if the metal just slipped off of it right below where the wrench goes on.
[IMG]local://upfiles/40715/FDBC357506C34AD0A8C07D73287A39BE.jpg[/IMG]
Old Sep 17, 2006 | 07:40 PM
das2123's Avatar
das2123
Default RE: Spark plug broke in unusual place PLEASE HELP!!!
Gotta pull the head and use an extractor to get it out.
Old Sep 17, 2006 | 11:56 PM
iravven's Avatar
iravven
fixed it.. used what i call an easy-out dontknow the real name for it, its sort of like a tap with left handed threads on it and i screwed it into what was left of the plug and spun it right out, damn you must always look at the glass half empty in order to say right off the bat that i have to pull the head but thanks anyways.. peacee
Old Sep 18, 2006 | 02:11 AM
das2123's Avatar
das2123
Ahhhh, the easy out....I didn't even think of that!!! It's a shame too, because I have one [8D]
Old Sep 18, 2006 | 03:04 AM
71RoadRunner's Avatar
71RoadRunner
What brand of plug is it? I've never seen something like that happen.
Old Sep 18, 2006 | 03:28 AM
ewetho's Avatar
ewetho
First look seems to be good 'Ol Champion. Ah well. Not the greatest plugs, as they say Champions are good for Lawn Mowers and Chryslers.
Old Sep 18, 2006 | 04:21 AM
DNeon's Avatar
DNeon
lol I couldnt really tell wat happened wit the pic so I edited it a lil an moved up the brightness...I was thinkin the same thing
ORIGINAL: 71RoadRunner
looks like the thread jus seperated from the ceramic...musa been a defective plug?
Old Sep 22, 2006 | 06:46 AM
dirtysohc79's Avatar
dirtysohc79
I bet he went righty tighty and not lefty lucy. I've done that soo many times with other bolts overtightening them.
Old Sep 22, 2006 | 07:39 AM
racerx55's Avatar
racerx55
i thought i was the only one in the world that ever had that happen with spark plugs, lol, mine were champions that broke like that, i played hell gettin mine out with an easy-out, but i very carefully got them unscrewed
i ended up welding an easy-out to an old 3/8 drive extension to be able to get to it
Old Sep 22, 2006 | 08:45 PM
NEONRT98's Avatar
NEONRT98
Err, I am no professional.. But isnt the DOHC head aluminum? I would be *VERY* careful with easy outs of they are... dont want to mess up the threads, else you may have a even bigger problem on hand
