Running like poo
Old Mar 21, 2006 | 07:35 PM
95neonwhite4dr's Avatar
95neonwhite4dr
Default Running like poo
I have a 95 neon 2.0 sohc that has been stuttering and backfiring ever since I ran it low on gas. trying to fix the problem I have replaced the fuel filter and the spark plugs. I also ran seafoam through the pcv system three seperate times, and each time I did it seems to be getting better. Am I on the right track, or is there anything else it could be? some people say it is the fuel pump and others say it is not, because a fuel pump either works or it doesn't, there is no "sometimes works".
Old Mar 22, 2006 | 08:56 PM
RadarLove's Avatar
RadarLove
Default RE: Running like poo
Is the Check Engine Light coming on at all? Head gasket ever been updated?
It's not uncommon for the SOHC to skip a tooth on the timing belt and still run. Could also be a cat that is nearing the end of it's life. Could be a cracked exhaust manifold.
Old Mar 23, 2006 | 01:29 PM
streetbikr600's Avatar
streetbikr600
it could be the fuel pump i have a msd fuel pump.....it could also be the fuel accumulator but that is not serviceable
Old Mar 23, 2006 | 04:18 PM
spudsterier's Avatar
spudsterier
sometimes when you run a car out of gas it will mess up the injectors...
Old Mar 23, 2006 | 11:47 PM
RadarLove's Avatar
RadarLove
Accumulator? Do you mean regulator? It's replaceable, and doesn't tend to fail, so a salvage yard part should do...
MSD makes a replacement pump for the Neon?
Old Mar 26, 2006 | 10:58 PM
95neonwhite4dr
I replaced the spark plug wires and now the car runs perfect, but I can not understand why a cel never occured. Apparently the wires were so bad that the car could barely run, and coincidentally this just happened on the same day I ran it low on gas.
