Oil Leak Help
Old 03-28-2006, 01:23 AM
ewetho's Avatar
ewetho
ewetho is offline
Default RE: Oil Leak Help
Head gasket being blown only leaks where it is blown. Did you lose the seal between the Oil passage and coolant, or was it between Cylinders, how about cylinder and coolant, etc etc. etc. only in a major blow would you get all symptoms. Just 2 cents.
Old 03-28-2006, 04:22 PM
grimmcs's Avatar
grimmcs
grimmcs is offline
Thanks that clears that up. Thanks for the help. We will probubly get started in a few days.
Hopefully it will just be the valve cover gasket.
Quick Reply: Oil Leak Help
