Tach hookup
Old Apr 5, 2006 | 01:46 AM
Neon97's Avatar
Neon97
Default Tach hookup
Question for ya, i got a 97 sohc neon with no tach stock, i recently bought one and i cant find where to hook it up. Any input is good
Old Apr 5, 2006 | 08:14 AM
HabitatHxC's Avatar
HabitatHxC
Default RE: Tach hookup
Dont quote me but i tried hooking up a tach once, (didnt work later i found out due to corroseion in the coil pack then i sold the tach)
Red, Black, Green, and White wires?
Red and White, are power and lights in the tach, red and white both to the battery or powersorce
Black Duh ground
Green, i hooked up to my coil pack middle wire, pick one test it and if it works Vwola!
any other wires i got no clue!
Old Apr 5, 2006 | 10:06 AM
spudsterier's Avatar
spudsterier
remove the cluster and on the right side plug thats still on the car there should be a wire thats grey with light blue stripe...if i remember right then thats the tach wire...
Old Apr 5, 2006 | 06:12 PM
casper's Avatar
casper
Mine is connected to the grey wire with the blue strip comming out of the PCM.
Old Apr 5, 2006 | 07:52 PM
highline95jl's Avatar
highline95jl
ORIGINAL: Neon97
You would find it easier and less ricey if you went out and bought a used stock tach out of a salvaged Neon, yea the miles would be different, you would have to write that down and it would be a hard sell on the car, but you wouldnt look like you have your kitchen clock sitting on your dash. Its also a lot easier to install.
Old Apr 16, 2006 | 03:35 AM
darianlow's Avatar
darianlow
How do you hook it up? with a splicer that just adds teh wire in with it or? any other ways?
Old Apr 16, 2006 | 05:35 AM
casper's Avatar
casper
ORIGINAL: darianlow
The power wires are the power wires, the pick up wire connects to the grey wire with the blue strip, there are a few places you can pick it up. Mine is connected to the wire comming out of the PCM, works great.
Old Apr 16, 2006 | 06:29 AM
darianlow's Avatar
darianlow
My PCM doesnt look anything like the one in the haynes manual, Mine has 2 seperate Connection points instead of 1 long one. Also how is the connection made? is it done with an inline splicer soo it just latches onto the side of the wire and draws a signal that way?
Old Apr 16, 2006 | 03:21 PM
RadarLove's Avatar
RadarLove
The PCM in the Haynes manual is from a '95, it's different. You can use an inline splicer or just cut the wire and splice onto it, since that wire isn't really doing anything at the moment...
Best fo luck!
Old Apr 16, 2006 | 03:33 PM
burpleneon's Avatar
burpleneon
i have mine hooked up behing the cluster, i hooked mine up in my 98 to a blue wire on the right side it was the top blue one, i jerry riged mine up and went through the wires to see wich one it was and found it
