Hooking up neon to laptop
Old Apr 5, 2006 | 04:26 PM
coocoobird's Avatar
coocoobird
Default Hooking up neon to laptop
Just wondering if anyone has done this? I have the software but, i wanted to know if all i needed now was a obd2 to serial or usb cable to hook into the laptop. I seen somethings that said it hooks into an interface box but, i was assuming you wouldnt need one if you have the laptop already?
Old Apr 5, 2006 | 05:12 PM
spudsterier's Avatar
spudsterier
Default RE: Hooking up neon to laptop
i got the whole deal for my car...it needs the little box deal, then you need the cable to go from the little box to the usb plug on your computer and then a cable to go from the little box to the obd2...
Old Apr 5, 2006 | 06:07 PM
coocoobird's Avatar
coocoobird
ORIGINAL: spudsterier
Which one did you get? How much? and where?
Old Apr 5, 2006 | 07:58 PM
spudsterier
pro scan its a scantool.net 100.00 ebay
Old Apr 6, 2006 | 04:31 PM
casper's Avatar
casper
Just curious, what are you guys planning on doing when you get the laptop connected. I am pretty sure you can do nothing more than monitor sensor readings. You can't reprogram the PCM.
Old Apr 6, 2006 | 04:37 PM
spudsterier
with the one i got it has a track performnce meter that gives the same readouts as goin to a strip, 1/4 mile,1/8 mile, 0-60, 1/4 mile speed and others...plus lets you scan the check engine codes and clear them out....and monitors all compatible sensors, vehicle speed sensor, rpm's, iat, and more...performs onboard tests...and more...i got it for the check engine light deal...works good too
Old Apr 6, 2006 | 06:08 PM
casper's Avatar
casper
Oh, ok, thats what I thought. I was hoping someone had come out with a way to program the PCM yourself.
Old Apr 6, 2006 | 06:48 PM
spudsterier
is that sarcastically???
Old Apr 6, 2006 | 06:54 PM
casper's Avatar
casper
No, I have seen the monitoring set-ups, I was just hoping someone had made a programming set-up.
Old Apr 6, 2006 | 09:05 PM
spudsterier
its got a deal that says it lets you mess with the pcm programming, but i dont know how and im not goin to mess with it
