smoke ?
Old Apr 10, 2006 | 03:35 AM
redr/t's Avatar
redr/t
Default smoke ?
what would make my neon blow black smoke when i shift?
Old Apr 10, 2006 | 08:43 AM
RadarLove's Avatar
RadarLove
Default RE: smoke ?
oil leakage past the rings
Old Apr 11, 2006 | 03:37 AM
evilneon's Avatar
evilneon
Default RE: smoke ?
past the ring were for example. mine does it when it idles to long? what does that mean?
ORIGINAL: RadarLove
Old Apr 11, 2006 | 04:16 AM
shnormo's Avatar
shnormo
Default RE: smoke ?
build up of oil in the cumbustion chamber. black equals oil white smoke equals water/coolant.
Old Apr 11, 2006 | 06:12 PM
highrevr/tflea's Avatar
highrevr/tflea
Default RE: smoke ?
Blowby
Old Apr 11, 2006 | 08:36 PM
ewetho's Avatar
ewetho
Default RE: smoke ?
Black smoke generally means to you are too rich, ie. FUEL. Blue Smoke is oil. Blue smoke on IDLE probably valve seals. on shift either rings if blue but generally black on shift means excess fuel. SO If you have mods like bigger injectors for cams or what ever then you may be too rich at times. Check your AIR FUEL mix.
Old Apr 12, 2006 | 12:44 AM
evilneon's Avatar
evilneon
Default RE: smoke ?
what about white smoke? thats water right.my friends blew out white smoke when idleing to long,whats that mean?
Old Apr 14, 2006 | 01:47 PM
71RoadRunner's Avatar
71RoadRunner
Default RE: smoke ?
White is water or moisture, you will have this when it sits idling for a while in cold weather especially. It is normal on start up in cold weather or idling for long periods in the cold, just like water drops coming out the tailpipe in the same conditions is normal, but not after it has reached operating temperatures.
