where is a good cai
Old May 23, 2007 | 05:16 AM
  #31
95neonriceeater's Avatar
95neonriceeater
Default RE: where is a good cai
any time man
Old May 23, 2007 | 05:27 AM
  #32
Short_Stack's Avatar
Short_Stack
btw does anyone ahve a picture with a diy or a real CAI actually in the car?
well here is the ebay on ($50-ish)
the diy 3.0 CAI
they look simmilar to me..........
Old May 23, 2007 | 05:44 AM
  #33
Short_Stack
here is a pic with it together
Old May 23, 2007 | 05:52 AM
  #34
95neonriceeater
with the 2nd post you put you might be able to relocate it to where the CAI would be
the diy intake is moved to underneith the battery
and that 2nd intake you posted from eBay might actually work if tahts the actual one
just slap a K&N filter on it
Old May 23, 2007 | 10:45 AM
  #35
spudsterier's Avatar
spudsterier
or you could relocate the filter behind the bumper
[IMG]local://upfiles/29901/B1F12EB8CEBC41EBAD49FCA1A16A3953.jpg[/IMG]
[IMG]local://upfiles/29901/BFB7F078A32F4A34A1C02FDBA2203810.jpg[/IMG]
Old May 23, 2007 | 11:17 AM
  #36
das2123's Avatar
das2123
ORIGINAL: Short_Stack
3.0L Intake...
[IMG]local://upfiles/33897/345F56D1B32F47AA9F0BDF9E205D7B7C.jpg[/IMG]
[IMG]local://upfiles/33897/6C6413D31C8A434F959D3FA8A794B099.jpg[/IMG]
[IMG]local://upfiles/33897/9D40FFF751724482B25E4F37FB4DA4B4.jpg[/IMG]
And here is the Iceman...
[IMG]local://upfiles/33897/89C7AC9771AF4BCC87850A2811444551.jpg[/IMG]
Old May 31, 2007 | 11:24 PM
  #37
marsh712's Avatar
marsh712
when done right, i think it looks pretty BA. nice pics das.
btw, im zach. new to the forums, came here looking for just this and found it. you guys are great. check my neon out and let me know what you think: http://www.cardomain.com/ride/2656156
specs are below.
Old Jun 1, 2007 | 01:36 AM
  #38
protivakid's Avatar
protivakid
ORIGINAL: greenlantern420
I have a heat sheild down there and also the filter sits way above the damn exhaust the the pic does show it well but its not even sitting anywhere close to the exhuast and as far as I can find out a ton of cold air comes thru the back of the hood and up around the back of the motor you can keep you red plastic iceman pos i'll go with what I got. I guess I should add also I made the heat shield with a break press i'm not talking about some stock crap.
Sounds like someone is mad that they bought the e-bay special and later realized it did nothing more than the stock intake performance wise. Also the iceman is plastic so that it does not conduct the hot heatfrom the engine. Your intake being metal not only sucks in the hot air from the engine/exhaust, but the piping also conducts the hot heat which then heats up the air in the pipe itself. Even the stock intake is plastic.
