Throttle Body
Old Apr 28, 2006 | 09:45 AM
spudsterier's Avatar
spudsterier
Default RE: Throttle Body
kinda like this...i left it all in the car and just used a hack saw....took about 5 minuites to cut the tray down:
[IMG]local://upfiles/29901/2F1194A330B049AF8873A66C6C217EA3.jpg[/IMG]
Old Apr 28, 2006 | 05:14 PM
FuzzRacer's Avatar
FuzzRacer
Nice, I see now, thanks for the info and pic I might try that out
Old Apr 28, 2006 | 08:26 PM
5.0LTREATER's Avatar
5.0LTREATER
I think the jeep 3.0 TB is 60 mm, not 52mm like the atx. This is why the slight, inexpensive, mods to make it work are worth the money.
Old Apr 28, 2006 | 08:36 PM
das2123's Avatar
das2123
ORIGINAL: 5.0LTREATER
But a 60MM TB w/o any supporting mods can actually hurt performance.
Old Apr 28, 2006 | 09:04 PM
5.0LTREATER
ORIGINAL: das2123
[/quote]
Absolutely no argument or discussion needed for that. You are correct. However, based on this post, I do not know what mods have, or have not been made. I was just pointing out that the Jeep TB was not 52MM like the atx. And yes I have micro'ed a 3.0 TB at 60MM, straight out of the junk yard.
We cannot build or mod a car for people on the forum, only provide them with information about how to do it themselves. But when we provide that information, we are morally obligated to insure that the information is factual to the best of our knowledge. There is nothing worse than delving into the unknown, and enlisting helpful information on the net, just to find out the help you received isn't worth a damn. Especially if it cost someone $$$ or physical harm.
So with that being said, it seems we have both acheived that goal, as both comments are very valid. Thanks for your input and comment as you may have saved this person some money that need not be spent at this time.
Old Apr 29, 2006 | 02:07 AM
FuzzRacer's Avatar
FuzzRacer
does anyone know the make/model and year of that jeep? I have enough mods that would support the upgrade so im not worried about hurt performance Actually I have a pulley that I still need to put on, I already have a 52mm I think the setup spud has would kick A** with a 60mm Ive been looking for that jeep throttle for a while but never got the info I needed I have the mod info to mod the throttle I just need the actually throttle now.
Old Apr 29, 2006 | 02:14 AM
das2123's Avatar
das2123
96-2001 Cherokee or Grand Cherokee with a 4.0L inline 6 cylinder engine and an ATX for the 60 mm TB. Good luck with it, it won't be easy! Have fun fabbing up the new mounting bracket.
The ATX one is 60mm, the MTX is 56mm.
Old Apr 29, 2006 | 05:18 AM
FuzzRacer's Avatar
FuzzRacer
Thanks, Im gona do some checking around if I have time tomorrow, Im suppose to go to a mudd run in Cardington OH. Fabrication is half the battle lol ok well maybe fabricating is more then half the battle but its still fun, that is when I don't end up getting burned or cut, Thanks a lot for the info I appreciate it.
Old May 2, 2006 | 01:39 PM
streetbikr600's Avatar
streetbikr600
how much hp would i see with a 55 tb in my car
Old May 2, 2006 | 01:44 PM
das2123's Avatar
das2123
ORIGINAL: streetbikr600
Depends on other mods, but with the mods you have listed in your sig not much. Maybe 2-4HP...
