It will not start....HELP!
Old May 1, 2006 | 02:10 PM
linzee23's Avatar
linzee23
Default RE: It will not start....HELP!
No I havent...I have no idea how to do that.[&o]
Old May 1, 2006 | 02:24 PM
das2123's Avatar
das2123
ORIGINAL: linzee23
You will need a fuel pressure gauge and connect to the fuel pressure test port on the fuel rail. It should test around 49psi. If lower than that you will probably need to change your fuel filter/regulator.
Old May 2, 2006 | 11:14 PM
linzee23's Avatar
linzee23
Ok I took it to a mechanic. He charged me $90 to say that it was the relay..that I had all ready checked. He replaced it and I drove it home. I took it for a drive to make sure it was fixed. It made it 2 miled and died again. Now it will not start at all???????????[:@]
Old May 2, 2006 | 11:54 PM
das2123's Avatar
das2123
Get the $90 back since it wasn't the relay.
Old May 3, 2006 | 07:12 AM
HabitatHxC's Avatar
HabitatHxC
ya no crap get your money back! Fightem if you have to!! could be the fuel pump too.
Old May 3, 2006 | 12:33 PM
linzee23's Avatar
linzee23
OK I towed it back to the mechanic and when he tryed to start it it started fine. He said it might take him a couple of days but he will find the problem. He said the money that I paid him yesterday will apply to the work he does on it today. So I guess now I am just waiting. Also I am getting code 42 now.
