It will not start....HELP!
Old Apr 30, 2006 | 09:29 PM
linzee23's Avatar
linzee23
Default It will not start....HELP!
I have a 95 neon. It had been running fine then I went out to start it in the morning and it took a few tries to get it started. Then about a mile down the road it died. It sat for a while then it started only when I stepped on the gas. Took off and it died again. I got it home and let it run for a while and it ran normal. So I drove it a little and it died in the same place again finally got it started and took it home.....now it just will not start............HELP ME PLZZ![sm=feedback.gif]
Old Apr 30, 2006 | 10:18 PM
casper's Avatar
casper
Default RE: It will not start....HELP!
Any codes?? How to check codes Any aditional information or stuff you have already checked would help alot too.
Old Apr 30, 2006 | 11:37 PM
linzee23's Avatar
linzee23
The only code i have been getting is 55. Checked the coil pack thats not it...new plugs and wires....all grounds are good. But the fuel pump dosen't make any noise when I turn on the key does that mean anything?
Old May 1, 2006 | 02:28 AM
das2123's Avatar
das2123
ORIGINAL: linzee23
That means it's not priming correctly or at all. Check your fuel pump fuse and relay.
Old May 1, 2006 | 02:41 AM
linzee23's Avatar
linzee23
The fuse is good. But how do you check the relay?
Old May 1, 2006 | 11:59 AM
das2123's Avatar
das2123
ORIGINAL: linzee23
Swap it out with the horn relay, honk your horn...if it works then your fuel pump relay is good.
Old May 1, 2006 | 01:29 PM
linzee23's Avatar
linzee23
Don't mean to sound stupid but......how do you get the relays out???
Old May 1, 2006 | 01:33 PM
das2123's Avatar
das2123
ORIGINAL: linzee23
Pull
Old May 1, 2006 | 01:56 PM
linzee23's Avatar
linzee23
lol ok no I feel stupid. Any way I switched them and the horn works.
Old May 1, 2006 | 02:05 PM
das2123's Avatar
das2123
Have you checked your fuel pressure?
