2.4 swap???
Old May 2, 2006 | 05:56 AM
luckydogg's Avatar
luckydogg
Default 2.4 swap???
do you guys know if you could hypothectically put a 2.4 turbo in a 99 neon? 2.0 sohc. has anyone done this? and is it worth it?
Old May 2, 2006 | 07:16 AM
HabitatHxC's Avatar
HabitatHxC
Default RE: 2.4 swap???
Yep yep and yep, It all depends on the time you have and the knowledge of mechanics you have.
Old May 2, 2006 | 09:01 AM
RadarLove's Avatar
RadarLove
Been done. Whether or not it's "worth it" is up to the owner. Being able to say you've done an SRT-swap into a 1st gen is pretty cool, even if it's gonna cost you $5-7k to have a 230ish HP car. You can build up a non-turbo PT Cruiser 2.4L to over 350 HP for less than that. Of course, if you manage to find a wrecked SRT-4 real cheap, I'd say pick up the FSM's for both years and hop to it.
Best of luck!
Old May 2, 2006 | 02:01 PM
das2123's Avatar
das2123
Here is a 2.4 Swap How-To adding the turbo would be easy since you have the engine out to begin with.
Old May 5, 2006 | 04:06 AM
luckydogg's Avatar
luckydogg
ok but what would be a easier swap or should i just keep the 2.0 and mod it???
Old May 5, 2006 | 07:17 AM
HabitatHxC's Avatar
HabitatHxC
I myself would choose the modding 2.0, because you dont have to fiddle with the motor mounts or electrical stuff if you want to work the motor.
Old May 5, 2006 | 11:45 AM
das2123's Avatar
das2123
ORIGINAL: luckydogg
I think thats an obvious question...it would be easier to mod what you have. You don't have to worry about fab work and cutting, splicing and so on, but you won't have as much HP. So you have to decide on what you want.
