pacesetter headers
Old May 13, 2006 | 09:19 PM
ScrapYurImport's Avatar
ScrapYurImport
Default pacesetter headers
what are possible hp gains from the pacesetter sohc headers?
Old May 13, 2006 | 10:31 PM
das2123's Avatar
das2123
Default RE: pacesetter headers
Depending on other mods, I'd say 2-5HP. Get the welds reinforced just to be safe!
Old May 13, 2006 | 10:39 PM
highline95jl's Avatar
highline95jl
And get the god damn performce cam if you have a 96+ Neon, no mods will do a damn thing with out it. That should be the first thing any SMART Neon owner should do.
Old May 13, 2006 | 11:13 PM
FuzzRacer's Avatar
FuzzRacer
I have the pacesetter header on mine( got that one because I have the exhaust as well and liked it) , noticed some gains if you choose to get it, dont use the paper gasket they include, get a better one and get the ceramic coated one to help reduce heat as well as have the welds gone over again like das said
Old May 14, 2006 | 12:22 AM
das2123's Avatar
das2123
ORIGINAL: highline95jl
Well I guess I'm not a SMART owner nor are many neon owners. That is not the first thing to do, is upgrade your cam. I would not suggest that unless you know full well what direction you are going with the neon. There are many cams to choose from, is the ony reason I would say that.
Old May 14, 2006 | 07:37 PM
ScrapYurImport
If you didn't notice I have a 95 neon and unless i'm mistaken they did come with the high performance cam?Right?
Old May 14, 2006 | 07:41 PM
ScrapYurImport
What other headers would you guys suggest? Are there any others that are made for my car that are better/cheaper than stock?
Old May 15, 2006 | 12:21 AM
das2123's Avatar
das2123
ORIGINAL: ScrapYurImport
It has the mpre agressive cam. Mopar actually started to sell it as a performance cam after the 95 year.
Pacesetter has shown the best improvements for the SOHC.
Old May 15, 2006 | 10:13 AM
spudsterier's Avatar
spudsterier
im sure that it couldnt be true about the cams....i dont see how there isnt any part out there that would make a difference without cams....it might be more noticeable, but you will still get gains without them
Old May 15, 2006 | 04:15 PM
highline95jl
ORIGINAL: spudsterier
Many respectable people on this site, RararLove, GaryHowell, and Casper have said over and over again that they had put on many a performance part and have gotten no real gains from them untill after a cam swap.
