Free flow muffler, cheapest, most quiet,
Old May 16, 2006 | 11:58 AM
Floor_it_Frank's Avatar
Floor_it_Frank
Default Free flow muffler, cheapest, most quiet,
added Horsepower.
Hi my 1998 Neon still has the original restrictive muffler. I want a high performance one but want it to be as quiet as possible and least expensive. What would guys recommend?
Thanks
Frank
Old May 16, 2006 | 12:01 PM
das2123's Avatar
das2123
Default RE: Free flow muffler, cheapest, most quiet,
Do you have a SOHC or DOHC?
Old May 16, 2006 | 12:04 PM
Floor_it_Frank
SOHC
Old May 16, 2006 | 12:09 PM
das2123's Avatar
das2123
A real cheap upgrade would be to put the DOHC muffler on there. It flows very well, is quiet, but will give you a little more agressive sound at WOT.
Old May 16, 2006 | 12:45 PM
jdog08's Avatar
jdog08
would that be the best choice or is there another muffler out there that is still quiet but gives more hp
Old May 16, 2006 | 01:39 PM
das2123's Avatar
das2123
ORIGINAL: jdog08
To stay quiet it would be. The stock DOHC muffler is designed very well from the factory. Aftermarket mufflers won't give any additional HP over the stock DOHC muffler because of it's design. Now if someone is going for looks, then it's a different story.
Old May 17, 2006 | 04:00 AM
redr/t's Avatar
redr/t
if u want a dohc exhaust i have the orignal in my garage give me a price ill sell it
Old May 21, 2006 | 07:09 AM
RadarLove's Avatar
RadarLove
The stock DOHC muffler is still restrictive. A straight-through muffler like the Hooker Max Flow or Dynomax UltraFlow will free up more HP, but there's the noise issue...
In addition to an aftermarket muffler, you could try running a long (42"?) Thrush Magnum glasspack in the long channel under the car (it's been done before), or even a Moroso Spiral Flow muffler will fit, although they have been known to fall apart internally...
Best of luck!
Old May 26, 2006 | 03:31 AM
ewetho's Avatar
ewetho
Mopar RT muffler is just about dead quiet unless you are at an ATM or other drive thru and rev it up pretty good and let is settle back down. Then you hear it from the dirvers seat. Other than that, Dead quiet.
Old May 26, 2006 | 05:06 AM
71RoadRunner's Avatar
71RoadRunner
Your best bet is probably the Dynomax Super Turbo muffler which is only around $40 and will perform as well as just about any performance muffler out there for the Neon.
