adding a temp gauge
Old May 17, 2006 | 04:01 AM
mnmattie's Avatar
mnmattie
Default adding a temp gauge
well I'm looking at adding an aftermarket temp gauge. Is there a place anyone would recommend installing one? Maybe an unused port on the radiator or something that I can tap into? thanks for any input guys!
-Mattie
Old May 17, 2006 | 11:51 AM
das2123's Avatar
das2123
Default RE: adding a temp gauge
There is a place on the back of the block to put one or you can put in the heater hose.
Old May 17, 2006 | 04:20 PM
FuzzRacer's Avatar
FuzzRacer
yeah there is one on the back of the block, I saw pics of where the location to put one in at on someother neon website, it looked really fun to reach that area have fun with that.
Old May 21, 2006 | 07:13 AM
RadarLove's Avatar
RadarLove
Personally, I'd go with an adapter right at the coolant neck, spliced into the rubber hose. You can pick these up at a hardware store like Home Depot. I forget what size you need to fit in the hose... You have to run a ground wire to the block or frame in order to get a signal, but you are getting the temp of the water as it comes out of the block. The spot I used in the back of the block didn't track very well with the sensor readings using a scanner.
Best of luck!
Old May 23, 2006 | 01:40 PM
streetbikr600's Avatar
streetbikr600
/Users/zeroperiod/Pictures/iPhoto Library/Originals/2006/Roll 9/P1020019.JPG[IMG]/Users/zeroperiod/Desktop/P1010009.JPG[/IMG]/Users/zeroperiod/Pictures/iPhoto Library/Modified/2006/Roll 9/P1010009.JPG
o wow that is the biggest pain in the A...i went out and got a copper pip drilled and taped a pipe thread for the sensor and tapped into my fuse box for power than bought side pillars for the guage
Old May 23, 2006 | 01:42 PM
streetbikr600
l
Old May 23, 2006 | 03:07 PM
das2123's Avatar
das2123
Pic's dont work
Old May 23, 2006 | 09:19 PM
tomthedog's Avatar
tomthedog
hook up to the rad dain plug. my 96 has one. easy to get to, might be some long wires and the temp might be a few points off, sure would be hella easy though.
