wtf my car got fixed today help!!!!!
Old May 23, 2006 | 03:57 AM
redr/t's Avatar
redr/t
Default wtf my car got fixed today help!!!!!
why does it wanna die under 3000 rpms i put a new egr valve on it and it ran well to work then it keeps trying to die whats rong with it
Old May 23, 2006 | 07:45 AM
RadarLove's Avatar
RadarLove
Default RE: wtf my car got fixed today help!!!!!
codes?
Old May 23, 2006 | 11:34 AM
das2123's Avatar
das2123
Need more info as to what it is doing...
Old May 23, 2006 | 02:09 PM
ewetho's Avatar
ewetho
Codes would help but that kind of problem is usually indicative of either EGR, IAC, or vacuum leak. EGR can be source of vacuum leak as well look carefully.
Old May 23, 2006 | 05:13 PM
redr/t's Avatar
redr/t
the only code was the egr and it went away when it was changed last night it dropped below 3000 and it stutters and almost stalled when i was stopped i had to hold the aclerator to keep it running it runs fine when moving
Old May 23, 2006 | 05:34 PM
das2123's Avatar
das2123
Is everything connected back correctly? The vacuum lines for the EGR?
Old May 23, 2006 | 08:29 PM
tomthedog's Avatar
tomthedog
i agree with das on this one. double check everything. although i think you car is too new to have cracked vac lines it is somthing to think about, did you have to bend some stuff out of the way, check the lines. if you took it to a shop they may have discon something wanting to get more $$$. that's just my 2 cents someone got a third?
Old May 24, 2006 | 04:20 AM
redr/t's Avatar
redr/t
wat is a iac
Old May 24, 2006 | 11:41 AM
das2123's Avatar
das2123
ORIGINAL: redr/t
wat is a iac
Idle Air Controller, there is a sensor and motor.
