cracked plastic intake
Old May 20, 2006 | 06:49 PM
tomthedog's Avatar
tomthedog
Default cracked plastic intake
i cracked my intake when changing the clutch (feel free to make fun). 96 2.0 sohc. have another 1st gen i can get parts from. all i know about the parts car is it has an auto trans. are the intakes the same for auto/stick and sohc/dohc? any repair advice? the part that broke off is below the throttle body, the lower bolt hole that hols the metal pipe coming from the "AIS?" valve. new to neons and the DF, any help wold be great. i work on chopper engines (the kind that fly) for uncle sam, so i have access to some pretty good epoxies/resins. anyone know how well the intake holds up to repairs? Suck. Squeeze. Bang. Blow. Before anyone asks, is how turbine engines work.
Old May 20, 2006 | 09:59 PM
Ramrat's Avatar
Ramrat
Default RE: cracked plastic intake
as long as they are both SOHC it should be a even swap
Old May 21, 2006 | 12:46 AM
das2123's Avatar
das2123
SOHC and DOHC intakes are different. SOHC's are plastic and DOHC's are aluminum. Get a plastic intake from a junker and swap it in.
Old May 21, 2006 | 07:21 AM
tomthedog's Avatar
tomthedog
thanks for the heads up. I'll give the junker a good look before a swap. just in case, any ideas about repairing the intake?
Old May 22, 2006 | 01:08 AM
das2123's Avatar
das2123
ORIGINAL: tomthedog
I wouldn't repair it, but that's just me!
Old May 22, 2006 | 04:52 PM
tomthedog's Avatar
tomthedog
i'm stationed in germany at the moment, might not have a choice. still waiting for the junker's time to expire at the impound lot before i can strip it. that's why all i know about it is the auto trans.
Old May 22, 2006 | 07:40 PM
das2123's Avatar
das2123
Give the epoxy a shot at it then.
Old May 23, 2006 | 07:48 AM
RadarLove's Avatar
RadarLove
Some SOHC's had an aluminum (one-piece) intake. I've still got mine in the back seat...
Best of luck!
Old May 23, 2006 | 11:32 AM
das2123's Avatar
das2123
ORIGINAL: RadarLove
I thought so, but wasn't sure. Any idea as to whay some SOHC got the aluminum intake?
Old May 23, 2006 | 03:45 PM
flamingpinhead's Avatar
flamingpinhead
Section Moderator
until you can get the junker stripped... use poxy or hell... just wrap it in ducttape
