how do u do an engine flush?
Old May 23, 2006 | 09:45 PM
neoncrazy101's Avatar
neoncrazy101
Default how do u do an engine flush?
Hey i'm gonna be doing an engine flush on both of my Neons but how do u do it and what type should i use? is Gunk Motor Flush ok? or would it dry out the gaskets?
Old May 24, 2006 | 02:06 AM
ewetho's Avatar
ewetho
Default RE: how do u do an engine flush?
Probably time to go over to Bitog and look for info on AutoRX seems to be their favorite. You'd want to be gentle with a high mileage engine. No super flushes at this point.
Is it really gunked up or just a light dark carmel color inside. Any leaks?
Old May 24, 2006 | 04:10 AM
neoncrazy101
well in my green Neon with 232,000 miles on whenever we change the oil as soon as we let it run for a little bit it gets all black ugly looking and i've been worried about it for some time (mostly due to the fact that i want it to last as long as possible). it doesn't have any major leaks. like we can go almost to 3,000 miles before having to add some. our red Neon on the other hand is going through oil like crazy and just like our green one it just gets all black and ugly as soon as we change it. our red one has over 200,000 miles and were trying to get it to last as long as possible as well.
Old May 24, 2006 | 06:10 PM
neoncrazy101
the main reason why i want to do an engine flush (if it wont hurt my engine) is because they are over 200,000 miles and have been neglected for probably 90% of their life. a now sense i own one of them i want to give it its overdue careness.
Old May 25, 2006 | 05:29 PM
tomthedog's Avatar
tomthedog
i hope you ARE NOT going to flush the oil system with a high mile engine. the reason your oil gets black really fast is the piston rings are getting worn allowing gasses to get into the crankcase and add extra carbon to your oil. your oil filter will get rid of any big chunks that are big enough to go through the oil pick-up tube screen.
think about this. Q: what breaks down/ flushes oil away?
A: solvents.
Q: how do you get the solvent out of the motor after daining?
A: you don't, it's still left in the oil passages to break down the fresh oil.
Q: what will solvents do to high mile gaskets?
A: let me know if you find out.
if you are talking about a coolant flush i'd take to a shop. call around, you should be able to get it done for $20-$30. no mess to clean and so on.
Old May 25, 2006 | 05:31 PM
neoncrazy101
well i have not done the engine flush... so i guess i wont anymore....
Old Aug 1, 2006 | 07:41 PM
TomBrooklyn's Avatar
TomBrooklyn
ORIGINAL: tomthedog
Hi,
- Is 124,000 considered high milage?
- Could another reason the oil gets dirty fast be there is solidified gunked up oil up all up and around the rocker arms?
- Would solvent residue problem be solved by changing the oil twice after running the flush stuff?
Old Aug 2, 2006 | 06:33 AM
LilRedNeon97's Avatar
LilRedNeon97
i have only 60+k on my car and EVERYTIME I get an oil change they try to get me to flush the engine. what the hell is their problem? Someone told me that it could be the worst thing to do....
Old Aug 2, 2006 | 02:50 PM
NEONRT98's Avatar
NEONRT98
Heh, is it a bigger chain of stores like pep boys or something like that? If so, I would say its a matter of money.. more money they can make off ya!
Old Aug 2, 2006 | 03:24 PM
tomthedog's Avatar
tomthedog
it kinda depends on how old the car is too. a 3 yr old car can have those miles, flushing the oil passages wouldn't be a prob for this example. the prob is as gaskets get old they get brittle, crack, and such. the oil wil start to seep into the gaskets and form a sluge around the cracks helping to seal the "leaks". when you flush the system you get rid of all the sluge allowing the cracks to leak freely.
best way to change the oil is to run the motor to norm operating temp then drain and change. good luck.
