OBD-2 Question
Old Jun 2, 2006 | 11:14 AM
MetalMilizia's Avatar
MetalMilizia
Default OBD-2 Question
I have a 1998 Dodge Neon (built in Canada) and I was looking to connect my laptop to the OBD port to monitor everything. I want to know if there is anything that can go wrong with the computer in my car or anything I should be aware of. I really don't want to mess something up then I can't drive it anymore. So is there anything I should know before trying this?
Old Jun 2, 2006 | 05:11 PM
NEONRT98's Avatar
NEONRT98
Default RE: OBD-2 Question
Might I ask what program you are using to do this? I have been wanting to do the same thing. And not to steal your thread or anything, but is there a program out there that you can manually alter your PCM through the OBD port with your laptop?
Old Jun 2, 2006 | 11:21 PM
MetalMilizia
I'm using a program from Scantool.net . Its an open source program. As for the PCM thing, I was reading another thread on here and it said that the PCM is encrypted in Mopar cars. Heres the link to that thread:
https://dodgeforum.com/m_441477/tm.htm
Hope that helps you out.
Old Jun 3, 2006 | 04:52 AM
NEONRT98's Avatar
NEONRT98
Awesome. By the way, I dont think you will mess anything up considering you said that things are encrypted, and that program more than likely is just to moniter things. Thanks again!
Old Jun 3, 2006 | 05:30 AM
RadarLove's Avatar
RadarLove
I used the scantool.net stuff for a few years (stolen about a year ago). No problems at all with the laptop of the PCM because of it.
Best of luck!
(P.S. - neons were only built in Toluca, Mexico and Belvidere, Illinois... )
Old Jun 3, 2006 | 01:39 PM
MetalMilizia
Thanks, is there a cable to connect a pocket pc rather than a laptop. i know that pocket pc's don't have usb ports. When I did a carfax report (which is a waste of money) on my car, if said it was manufactured in Canada. I don't know if they are telling the truth or not.
