Installing new speakers
Old Jun 7, 2006 | 05:02 AM
kellyannerev's Avatar
kellyannerev
Default Installing new speakers
Does anyone know how to take the interior door panel off to replace the front speakers?
Old Jun 7, 2006 | 09:33 AM
spudsterier's Avatar
spudsterier
Default RE: Installing new speakers
power windows or crank????
Old Jun 7, 2006 | 05:00 PM
kellyannerev
crank. it's a 1997.
Old Jun 7, 2006 | 05:58 PM
dogdaysunrise's Avatar
dogdaysunrise
take a towel and wiggle it under the crank to pop it off, then take out the screw under the door handle on the inside, and the screw that holds in the door cup. then just GENTLY pop the door off the plastic tabs. you should be able to lift it up and out.
Old Jun 9, 2006 | 02:14 AM
unclemike's Avatar
unclemike
Use a shop rag a towel might be too thick. Also be careful you don't send the little horseshoe spring flying.
Old Jun 9, 2006 | 02:20 AM
spudsterier
i think a shop towel would rip easily, since i have even ripped many rags doing it
Old Jun 9, 2006 | 09:03 AM
unclemike's Avatar
unclemike
Shop towels are a little heavier and have a sewn edge. We forgot to say that you put whatever you use under the crank arm and work it down to the center.
Old Jun 9, 2006 | 04:14 PM
bishop's Avatar
bishop
i find it alot easyer just 2 use a little pick and take the horseshoe clip straight out
