SRT4 swap almost complete
Old Jun 22, 2006 | 01:50 AM
das2123's Avatar
das2123
Default RE: SRT4 swap almost complete
ORIGINAL: 99SRT4
will the AOBE be safe
Yes! You have to go around the MAP sensor somehow.
Old Jun 22, 2006 | 02:37 AM
99SRT4's Avatar
99SRT4
Do you have to use the AOBE whan you turbo a 99 dohc motor? I used the sensers from the 99 motor.or is there a performance computer that i con use
Old Jun 22, 2006 | 02:59 AM
das2123's Avatar
das2123
You have to use the AOBE, map clamp, or a missing link to go around the MAP sensor if you are using the stock PCM. The stock PCM CANNOT see boost. Aftermarket PCM's advance timing which is bad on a turbo car. I already said this...Most people who do the SRT engine swap just go with a Stage 1 PCM that hasn't seen the Sentry.
Old Jun 23, 2006 | 05:08 AM
99SRT4's Avatar
99SRT4
i got the AOBE and 3'down pip to day
Old Jun 23, 2006 | 12:21 PM
das2123's Avatar
das2123
ORIGINAL: 99SRT4
Nice, a little bit closer now...
Old Jun 23, 2006 | 03:05 PM
99SRT4's Avatar
99SRT4
whating fuel pump from moden performance,innercooler piping boost controler than im done for now. do you know of any body saling used srt4 performance parts.
Old Jun 23, 2006 | 03:12 PM
das2123's Avatar
das2123
Not personally, but check out srtforums.com for sale forum...
http://www.srtforums.com/forums/forumdisplay.php?f=27
Old Jun 24, 2006 | 12:02 AM
99SRT4's Avatar
99SRT4
can i start the car with out the intercooler piping???? I just need to see if the car start.
Old Jun 24, 2006 | 01:15 AM
das2123's Avatar
das2123
Uhhhh.....I think so!
Old Jun 24, 2006 | 04:47 AM
99SRT4's Avatar
99SRT4
it didint start....it trid to and backfired my boy with a GST told me it whold not so i ges ill wet[>:]
