no more codes but idle still messed up
Old Jun 23, 2006 | 12:26 PM
bishop's Avatar
bishop
Default RE: no more codes but idle still messed up
actually i was just about to make another thing but sence this ones already open , i replaced teh head on my neon because i bent the valves on the last one *timeing belt broke* and now when i start it it revs at bout 1300 i was also told it must be a vaccume leak , how should i go about finding it ? the same way that you just mentiond and also i scanned it and the only code i got was that target idol not reached
Old Jun 23, 2006 | 12:28 PM
bishop's Avatar
bishop
and where exactly should i look for leaks and how should i go about fixing them * i have 2 go up teh country today in teh car and its an hours drive it whould be nice to have it fixed
Old Jun 23, 2006 | 12:39 PM
das2123's Avatar
das2123
Have either one of you taken out the IAC motor and cleaned it up? It could have carbon buildup.
Old Jun 23, 2006 | 12:42 PM
bishop's Avatar
bishop
whats the best way to go about that
Old Jun 23, 2006 | 01:06 PM
das2123's Avatar
das2123
ORIGINAL: bishop
You gotta take the TB off to get to it and then clean it.
Old Jun 24, 2006 | 07:48 PM
racerx55's Avatar
racerx55
ORIGINAL: das2123
How abourt a spray bottle with a mixture of soap and water...works for me.
how do you expect to find a VACCUM leak with soapy water?
you find a pressure leak (such as a tire) with the bubbles,
Old Jun 24, 2006 | 09:03 PM
das2123's Avatar
das2123
ORIGINAL: racerx55
ORIGINAL: das2123
DOH, I got mixed up...sorry!
Old Jun 25, 2006 | 03:07 PM
tomthedog's Avatar
tomthedog
is the intake still wraped in tape or am i thinking of another? i had code 25 and a high idle 'till i fixed my cracked intake with epoxy.
