PLEASE HELP
Old Jun 21, 2006 | 09:00 PM
dodgeit100677's Avatar
dodgeit100677
Default PLEASE HELP
I have a 1997 plymouth breeze and I wanna put a turbo on it. I'm wondering being that the only difference between the breeze 2.0L, and the neon 2.0L is that the pulley's are different and altenator, etc. are mounted in different spots. Will a neon T3 turbo work on a breeze?
[IMG]local://upfiles/37717/995C9D5D2A634C459275AEF17DC4BA53.jpg[/IMG]
Old Jun 21, 2006 | 10:00 PM
dodgeit100677
Default RE: PLEASE HELP
Is there any way to pick up about 100+ hp without a turbo and without going completely broke
Old Jun 21, 2006 | 10:54 PM
RadarLove's Avatar
RadarLove
You aren't going to pick up 100+ HP with a turbo on the stock bottom end, stock compression. Typicaly it's the rods that bend somewhere in the 250ish ft-lb torque range, although with the compression dropped (thicker head gaskets, etc.) they'll hold up to a little more.
Dollar for dollar, a well built nitrous setup will get you the most for your money. You could do a 50 shot pretty reliably. You could probably do a 75 shot if you throw in a timing retard unit and spend some time at the dyno tuning the setup.
A Nitrous Express kit, as well as the GenX upgrades (HIGHLY recommneded), and an upgraded fuel pump will run you maybe $1200 if you shop around. A bolt-on intercooled turbo setup is running $3500 or so nowadays. Both will get you in the 225ish HP range. You can do a DIY turbo setup for probably half that IF you know what you're doing. A T3 isn't going to cut it...
If it was me, just adding a little oomph to a daily commuter, I'd go the turbo route. For a car that is built for straight-line fun at the track, I'd go the nitrous route.
Best of luck!
Old Jun 22, 2006 | 12:14 AM
das2123's Avatar
das2123
^^^Not to mention the reliability issues of having a turbo.
Old Jun 23, 2006 | 02:09 AM
dodgeit100677
I dont really wanna go the notrous route with this car yet its still a daily driver for me and the wife with kids, I just want to be able to go when I get the urge to. At this moment in time the car is completely stock any other suggestions?
[IMG]local://upfiles/37717/AED5520FD7694C9E9457464959BBC960.jpg[/IMG]
Old Jun 25, 2006 | 05:57 PM
rrwertz's Avatar
rrwertz
You're going to blow the car up before you get it out of the driveway with a stock 2.0. At the least you'd need a stronger bottom end.
Easiest and cheapest turbo is stock srt-4. i'm going to turbo my 2.4 when I have enough money for all the little crap I need. Already have the manifold, turbo, bov, manifold, etc.
Only kit you can really buy atm is a Hahn racecraft kit. Chillfactory is no longer taking orders.
Old Jun 25, 2006 | 06:44 PM
das2123's Avatar
das2123
ORIGINAL: rrwertz
Hahn doens't make a kit for the Breeze do they?
