oil
Old Jun 22, 2006 | 03:12 AM
jdog08's Avatar
jdog08
Default oil
ok today i was helping my friend work on his jeep and we were looking at the throttle body and it was covered in oil or a mixture of oil and gas i couldnt really tell and then we took the throttle body off and noticed that the intake manifold was the same way. At first thought i am pretty sure this isnt right so i was wondering what could cause this or if that is normal o and also some how oil or something is getting in the air filter
Old Jun 22, 2006 | 03:34 AM
IGottaFreeNeon's Avatar
IGottaFreeNeon
Default RE: oil
I think that is caused from a bad PCV (positive crankcase ventilation) valve. I'll check my Haynes manual for sure but I think that is what it is caused from.
Old Jun 22, 2006 | 10:29 AM
spudsterier's Avatar
spudsterier
Default RE: oil
yeah its the pcv....my wifes jeep does the same thing, the air filter get covered and then gets sucked into the intake.....just need a new valve
Old Jun 22, 2006 | 12:01 PM
das2123's Avatar
das2123
Default RE: oil
ORIGINAL: spudsterier
Best part is...it's a cheap and easy fix! Like $5 or something. Be careful with the hoses, they may be brittle and break on you.
Old Jun 22, 2006 | 02:26 PM
spudsterier
Default RE: oil
when i changed the headgasket on her jeep, the motor had 210,000 miles...went to take that hose off and broke it in about 6 or 7 places.....i still need to get a new one before we sell the jeep
Old Jun 22, 2006 | 11:37 PM
jdog08's Avatar
jdog08
Default RE: oil
PCV is the valve thing on top of the valve cover right
Old Jun 22, 2006 | 11:42 PM
spudsterier
Default RE: oil
yeah, and has a tube that goes to the air filter box
das2123's Avatar
das2123
Default RE: oil
ORIGINAL: jdog08
Nope, depending on your year it should be on the back side of the valve cover, passenger side, in front of the coolant reservoir and power steering reservoir.
Old Jun 22, 2006 | 11:44 PM
das2123's Avatar
das2123
Default RE: oil
That's not the PCV valve. How would you change that?
spudsterier
Default RE: oil
on a jeep its on top of the valve cover towards the front, shaped like an L
