Anyone want an Iceman?
Old Jul 8, 2006 | 09:31 PM
das2123's Avatar
das2123
Default RE: Anyone want an Iceman?
ORIGINAL: 95NeonJS
If I may ask, why is your friend selling the ICEMAN anyway?
He went turbo!!!! I will know something on Monday, if he still has it, I will PM you!
Old Jul 9, 2006 | 03:08 AM
95NeonJS's Avatar
95NeonJS
Thought about it. And went down to home depot to get all the parts to do it. Then realized that I wanted to re locate the battery to the trunk if I was going to make my own... Might as well just buy this one off Das' friend if he still has it. If not... Time to buy some battery cables!
Old Jul 9, 2006 | 03:22 AM
NEONRT98's Avatar
NEONRT98
You dont have to relocate the battery...
Disconnect the battery, remove it from the tray
Remove the bolts that hold the tray in, there are 3 or 4 I beleive..
Remove the tray, take a cutting wheel or cutting instrument of choice and lob off the little air intake thing on the front that is blocking your access to where you want the intake
Replace tray and battery, form CAI..
Old Jul 9, 2006 | 06:24 PM
95NeonJS's Avatar
95NeonJS
I don't want to run the CAI to the back where that box is located. It gets to hot right above the exhaust manifold. I want it under the front fender so I can pick up mostly cold air. Besides relocating the battery, even just a bit higher up would free up a lot of room.. (Which there isn't in the neon engine bay.) I did a full engine swap, watch your fingers.
Old Jul 9, 2006 | 07:06 PM
spudsterier's Avatar
spudsterier
you could make anything with the right stuff
[IMG]local://upfiles/29901/13FB4FB2C87942DC9B8ED59041687A13.jpg[/IMG]
Old Jul 10, 2006 | 07:25 PM
95NeonJS's Avatar
95NeonJS
ORIGINAL: das2123
quote]He went turbo!!!! I will know something on Monday, if he still has it, I will PM you!
Thanks Das I look forward to hearing back
Old Jul 10, 2006 | 10:22 PM
das2123's Avatar
das2123
ORIGINAL: 95NeonJS
ORIGINAL: das2123
That one is sold, but I may have another. Stay tuned...
Old Jul 11, 2006 | 12:08 AM
95NeonJS's Avatar
95NeonJS
what about going with an AEM, injen or another brand? I hear ICEMAN is the best, but all in all I've seen DYNO results that yielded the same as ICEMAN with one made from home... I went to Home Depot to look for a U mandrel bent tube, but then realized that I want to get pictures of peoples homemade CAI's i know there were a couple posts... I don't know why i'm posting this question without searching.. I'm not that lazy
Old Jul 16, 2006 | 10:15 PM
das2123's Avatar
das2123
I know a couple of guys that each have an Iceman for sale. It is just for the tube only, NO FILTER OR TRAY. You can trim your stock battery tray and buy a filter to use. I think they want $75 for the tube. Let me know if anyone is interested. They go quick!!!!
*edit* 1 is red and the other yellow.
Old Jul 17, 2006 | 08:58 AM
redr/t's Avatar
redr/t
i want one
