ThrottleBody
Old Jul 17, 2006 | 06:12 PM
Jellysrus's Avatar
Jellysrus
Default ThrottleBody
Hey i heard that if you have a manual to add hp you can get the throttlebody off an auto because the auto has a bigger one and it will add hp is this true???[X(]
Old Jul 17, 2006 | 07:35 PM
dogdaysunrise's Avatar
dogdaysunrise
Default RE: ThrottleBody
yes its true the atx tb is 52mm
Old Jul 17, 2006 | 08:01 PM
spudsterier's Avatar
spudsterier
ive got one from an auto on my manual....works out fine
Old Jul 17, 2006 | 08:02 PM
das2123's Avatar
das2123
ORIGINAL: dogdaysunrise
Compared to the MTX which is 49mm. You will notice a better throttle response as well.
Old Jul 22, 2006 | 02:55 AM
Jellysrus's Avatar
Jellysrus
all right sweet but what about a tb from a 2nd neon or the srt4 will they fit i bet not huh[X(]
Old Jul 22, 2006 | 04:43 AM
FuzzRacer's Avatar
FuzzRacer
not sure about the 2nd gen neons but I know a jeep cheeroke 3.0 TB will work with some modification, the jeep has a 60mm TB Im not sure which years though. that was discussed here before and even the instructions. so a good search will yield what you want if you choose to look into the jeep TB hope some of that was helpfull and good luck
Old Jul 22, 2006 | 10:01 AM
spudsterier
jeep 4.0
Old Jul 22, 2006 | 01:49 PM
das2123's Avatar
das2123
ORIGINAL: Jellysrus
Not without modifying and even then I don't think they aren't worth it.
Old Jul 22, 2006 | 08:40 PM
Jellysrus's Avatar
Jellysrus
alright thx looks lik[X(]e ill being getting an atx tb
