what happens when too much oil is added? PROBLEM?
Old Jul 19, 2006 | 04:03 AM
neoncrazy101's Avatar
neoncrazy101
Default RE: what happens when too much oil is added? PROBLEM?
ORIGINAL: das2123
ORIGINAL: tomthedog
if you have too much oil in, the crank shaft can hit the oil and turn it into "froth" causing an oil starvation issue.
That or you can cause hydrolocking. Hydrolocking occurs when liquid fills a cylinder on the intake stroke and, due to the incompressibility of a liquid, makes the compression stroke impossible. This, in turn, prevents the entire engine from turning, and can cause significant engine damage if one attempts to forcibly turn over or start the engine.
never knew that it could cause hydrolock... scary...
