Starting problems
Starting problems
Ok well I was replacing my Illm lights in my dash the other day because they went out. Well after I looked at what kind I need (pc194) I go to start my car, but get nothing. It turns over and sounds fine just will not fire. Tryed jumping and nothing. Checked battery voltage and that is fine. So I go to get it towed a day later, try to start it for one last time, nothing try again, starts right up and every time after that. The first time it started it seemed like it was going to cut off till i gave it some gas. Now that it runs, the check engine light is on. Any help or suggestion on the problem would be good?
RE: Starting problems
I will do that when I get home from work, I took it to the shop but they havent even looked at it for 2 days. So I am just going to bring it home now that I found out how to check the codes myself. Is there any reason with out the codes you can think of that it might do this? One thing is, we looked at the fuel pump fuse pulled it out and nothing happened but the next morning it started. Could it have been a lose connection from the fuse to the box?
get a bud and check with a multi-meter/test light. one of you check the reading/light while the other shakes the wires ALL along the path of power, from the batt to the pump/fuel injectors. sounds crazy but most of the time i find this prob with choppers (the kind that fly). hope this helps, good luck.
