water pump
Old Jul 24, 2006 | 10:03 PM
dm_rep's Avatar
dm_rep
Default water pump
i need some help replacing the water pump. can anyone help??????
Old Jul 24, 2006 | 10:12 PM
NEONRT98's Avatar
NEONRT98
Default RE: water pump
Get yourself a Chilton or Haynes manual, will get you pretty far!
Old Jul 24, 2006 | 10:35 PM
dm_rep's Avatar
dm_rep
i have the haynes and it got me for but not far enough
Old Jul 24, 2006 | 10:56 PM
DNeon's Avatar
DNeon
how far along are you? I jus took out my engine not to long ago.
you prolly dun wanna take out your engine so the space would b pretty tight, you gotta take out the engine mounts, it'd b easier to move it up or down a bit....dependin on where you wanna work on it.
wats the km or miles on your car? you mite wanna change the timing belt an serpentine belt(s).
Old Jul 24, 2006 | 11:11 PM
dm_rep's Avatar
dm_rep
im all the way down to the rear cover. once i get that off then i can remove the water pump, but i cant take off the rear cover until i get the cam gears off. thats where im stuck.
Old Jul 25, 2006 | 12:04 AM
DNeon's Avatar
DNeon
haha I got stuck there too....cams keep turnin....wat I did was, ok behind the cam gears there should b a bolt around the bottom half of each gear. I stuck a socket on the bolts to hold the gears in place. hope that helps.
nother thing is it SOHC? mines a DOHC, I'm assumin its DOHC cause you said gears.
Old Jul 25, 2006 | 02:08 AM
spudsterier's Avatar
spudsterier
if you dont have an air ratchet or impact wrench.....you can put the timing belt around the gear and hold it tight while you loosen the bolt...or stick a screwdriver between the spokes on the gear and find sumthing to pry off of.....or hold one of the spokes with a pair of channel locks and pull up while loosening the bolt
Old Jul 25, 2006 | 02:38 AM
das2123's Avatar
das2123
ORIGINAL: dm_rep
I hope your doing the belt and tensioner while you are at it...
Old Jul 25, 2006 | 03:20 PM
dogdaysunrise's Avatar
dogdaysunrise
just get a buddy with a big pry bar, you can pry the rear cover out far enough that you can get in behind it with a 3/8s ratchet to get the water pump off.
