Stumble when starting
Old Jul 30, 2006 | 06:02 PM
darianlow's Avatar
darianlow
Default Stumble when starting
So I sit in my neon and turn the key on it starts up right away with the narmal high rpm boost then it lowers but instead of going to idle it goes way down to almost liek 400 rpm or less then it jumps back up to 900. what is going on ?
Old Jul 30, 2006 | 06:06 PM
darianlow's Avatar
darianlow
Default RE: Stumble when starting
Also all I get is a 5-5 so the pcm isnt picking up on anything
Old Jul 30, 2006 | 07:41 PM
NEONRT98's Avatar
NEONRT98
Mine does the same thing, and then when it does recover, its a really rough idle, so I rev up the engine and a bunch of black **** comes outta my tail pipe. I think its either the humidity around here lately or it could be my EGR valve too (I know mine is bad)
Old Jul 30, 2006 | 09:41 PM
das2123's Avatar
das2123
EGR was my problem on my old 99 neon.
Old Jul 31, 2006 | 03:51 AM
darianlow's Avatar
darianlow
So where abouts is my EGR, and I will change it cause that problem scares me
Old Jul 31, 2006 | 05:26 AM
NEONRT98's Avatar
NEONRT98
Heh, the EGR setup is on the right hand side of your engine.. You have to remove the battery, battery tray, and move the fuse box to get to it... Then after that, you have to have a bit of finess to get to it.. It can be very tricky and frustrating... I think I am just gonna block mine off because we dont have E-check in my county :-D If you pick up a Haynes manual, it will give ya the lowdown on how to get it out
Old Jul 31, 2006 | 01:02 PM
darianlow's Avatar
darianlow
ahh I saw it in my haynes, im hoping its just a vaccume leak somewhere.
