Pealing Out
Trending Topics
Two words: Neutral Drop
If you don't really care about your car, put it in "N", rev it up to 5000 rpm then slam it into "D" and floor it at the same time. You could get a 3 cylinder geo to peal out doing that. Or maybe your car will just blow up. Either way I'm sure you will impress your friend.
Here's another idea. Lube up your tires with motor oil. That should do it. Of course you'll probably up in a ditch on the way home, but just like above, either way your friend will be impressed.
BTW, I take no responsibility for damage to your car or anything else if you actually do this.
neutral drops.....thats stupid to even mention....even sarcastically....
automatic neons are not geared to peel out....the valve body limits this...
unless you do some good mods your not gonna get it too......but if thats what you wanna do then i woud recommend getting a performace valve body....roughly about 250.00 then you can peel out all you want
