Am I correct in saying that all UDP's are going to vary a little in diameter or they all the same? I'm assuming that they are all different and that if I get one I'll need to do like Spud and experiment half a dozen times before I get the correct belt. If I am right how do you go about getting the correct belt? Is there a calculation or measurement or do you just kind of guess and check?
I don't know if they are all the same in diameter, but all you need to do after you get it on is use a picec of string and measure the diameter and then go bet a belt that size.
