Old Aug 6, 2015, 01:04 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Lighting
Print Wikipost
dome light cover?
Old Aug 1, 2006 | 12:17 AM
speedneon's Avatar
speedneon
Default dome light cover?
how do you remove the dome light cover?
Old Aug 1, 2006 | 12:41 AM
spudsterier's Avatar
spudsterier
Default RE: dome light cover?
push the headliner up against the ceiling and hold it there....while doing so, stick a screwdriver between the cover and the headliner and twist...should pop right off....you might even be able to pull it off with your fingers
i only say to push the headliner up to make sure you dont pull the whole domlight setup out of the headliner, and crease the liner
Old Aug 1, 2006 | 01:07 AM
speedneon's Avatar
speedneon
thanks alot man
Old Aug 2, 2006 | 06:42 AM
LilRedNeon97's Avatar
LilRedNeon97
if you havent noticed yet, you will soon learn that the Neon is pretty much made out of Lego!! lol or at least I think Lego and Neon had the same design team behind them.. hahahaha!!! well, ok, sometimes i just think that they did....
Old Aug 2, 2006 | 09:33 AM
spudsterier
pretty much..
you can almost take an entire neon apart by pulling, or using a philips screwdriver, 10, 13, and 15 mm sockets
