smoking
Old Aug 1, 2006 | 08:46 PM
93 tona's Avatar
93 tona
Default smoking
need linkage grommets to transmission,02 sensors, egr valve. any got how much I live in st louis and my cars smoke every once in a while in idle it a dohc manual. is this cause of the parts i need?
Old Aug 1, 2006 | 09:20 PM
FuzzRacer's Avatar
FuzzRacer
Default RE: smoking
Not really sure on what your saying somewhat but, the smoking could mean that your burning oil somewhere, does it overheat while in idle, does it over heat period? with the things you listed it sounds like your car is probably riding ruff especially with the O2 and egr valve issue, that's part of you emissions and can affect the car how did you come to these issues being possible problems? have you pulled the codes yet? if not then pull the codes and let us know please. hope some of that was helpfull and good luck !!
Old Aug 1, 2006 | 09:56 PM
Whatsrt4's Avatar
Whatsrt4
Default RE: smoking
It could be because of the ox sensors,my car does that sometimes to.I think it gets a bad reeding and sends the motor more gass than it needs.If it is realy a prob try pulling fuel pump fuse for 30 secs to reset computor.That is a temp fix only though.These cars seem to have very sensative ox sensors
