auto trans fluid?
Old Aug 8, 2006 | 03:01 AM
fetus's Avatar
fetus
Default RE: auto trans fluid?
Quick question. What do I do if I used the other atf (not mopar)?
Old Aug 8, 2006 | 03:05 AM
das2123's Avatar
das2123
ORIGINAL: fetus
Do a flush with the correct Mopar fluid, or if you like one of the "acceptable" ones I mentioned earlier.
Old Aug 10, 2006 | 03:18 PM
fetus's Avatar
fetus
how many quarts of "acceptable" atx fluid do i need to do a flush?
Old Aug 10, 2006 | 03:22 PM
das2123's Avatar
das2123
ORIGINAL: fetus
If you are draining and refilling it's 4 or 5 quarts. If you drain the torque converter also, then it's 8-9 quarts.
Old Aug 10, 2006 | 03:45 PM
JDC420's Avatar
JDC420
How much fluid do the manny tranny's take?
Old Aug 10, 2006 | 03:53 PM
das2123's Avatar
das2123
ORIGINAL: JDC420
About 2.5 quarts.
Old Aug 10, 2006 | 04:47 PM
JDC420's Avatar
JDC420
Ok, thanks. BTW Is it the type of tranny that you can fill to the top of the fill hole when topping up?
Old Aug 10, 2006 | 07:02 PM
tomthedog's Avatar
tomthedog
on a mtx (stick), yes. pull the drain plug and drain. put the drain plug in and pull the fill plug. fill until the oil almost leaks out the fill port. happy motoring.
Old Aug 10, 2006 | 07:32 PM
das2123's Avatar
das2123
The fluid level should be within 3/16 inch from the bottom of the transaxle fill hole when level.
