fuel/speed mixture
Old Aug 13, 2006 | 06:02 PM
neoncrazy101's Avatar
neoncrazy101
Default fuel/speed mixture
Hey i was wondering what the best speed for a Neon with the SOHC and automatic is? like when it comes to gas mileage....like i know in my 5-spd Neon its roughly about 80 where i get the best gas mileage but what about with the automatic?
Old Aug 14, 2006 | 02:37 PM
das2123's Avatar
das2123
Default RE: fuel/speed mixture
Lower RPM's=better gas milage
Old Aug 14, 2006 | 03:05 PM
neoncrazy101
ORIGINAL: das2123
thats what i thought....but didn't work too well in my 5-spd for some reason.... i got like 26mpg going 55mph (RPMs roughly about 2200) but yet when i go around 73 or so with the RPMs roughly 2800 or so i get about 34mpg.....strange....
Old Aug 14, 2006 | 03:32 PM
FuzzRacer's Avatar
FuzzRacer
Neon highway miles are the best, I set mine on cruise control and let it doe It's thing, sometimes I wish it could steer it's self lol.
Old Aug 14, 2006 | 03:59 PM
dogdaysunrise's Avatar
dogdaysunrise
2800 rpm is where the neon is making its ideal power. Although the rpms are higher the car has to do less work to keep moving re: you dont have to give it much throttle at all to keep it at that speed.
For the auto, you should try and find that same rpm range to get the best millage. However it will be far less of a speed because of diffrent gear ratios.
My truck gets the best gas millage (16mpg) at about 2100 rpm, but that is a small block v8. Its only about 65mph though, but that is because of my gearing also lol. I am running 35" tires with 3.42 gear ratio, and I have to keep my tranny in 3rd which is 1:1.
Old Aug 14, 2006 | 04:04 PM
FuzzRacer's Avatar
FuzzRacer
dogdaysunrise, how much does it cost to fill up the truck?
Old Aug 14, 2006 | 04:08 PM
dogdaysunrise
It cost me about 100 bucks to fill it from empty. Thats at 1.14 a litre at the pump, with regular dog water pump gas. However that cant even hold a candle to my work van at 150 bucks to fill. Its a big pig of a 1 ton that gets about 9mpg. Luckly I dont pay the gas bill
Old Aug 14, 2006 | 04:40 PM
FuzzRacer's Avatar
FuzzRacer
ouch that hurts, yeah your real lucky, gotta love the work vehicle's. it only costs me 36 to fill the neon up, but now it cost a little more since gas went up to $3.15 it's suppose to get up to 4 soon
Old Aug 14, 2006 | 05:59 PM
neoncrazy101
wow...it only cost me about 20 to fill up my Neon...but then again we dont drive it till its empty... we fill it up every 200 miles....due to the fact that the fuel gauge doesn't work
Old Aug 14, 2006 | 06:16 PM
FuzzRacer's Avatar
FuzzRacer
yup, 36 technically it's more because it's a 12.5 gallon tank but I just go with 3 gallons per .25 tank because I don't let the tank get to the .5 gallon point. I always keep a 2.5 gallon container in the trunk.
