Throttle Body Question
Old Aug 24, 2006 | 04:42 PM
neon15's Avatar
neon15
Default Throttle Body Question
I read that the MTX TB is 49 mm but choked down to 46.5 mm just in front of the plate. Is this true? if so can you "un choke" it
Old Aug 24, 2006 | 04:54 PM
das2123's Avatar
das2123
Default RE: Throttle Body Question
I've never measured it, but you could bore it out.
Old Aug 24, 2006 | 06:03 PM
95neonriceeater's Avatar
95neonriceeater
how do you bore it out
Old Aug 24, 2006 | 06:08 PM
das2123's Avatar
das2123
You probably need a machins hop to do it and you will need a bigger butterfly plate also.
Old Aug 24, 2006 | 09:10 PM
neon15's Avatar
neon15
so a 55mm TB issnt worht the extra money....your better off getting a ATX TB?
Old Aug 24, 2006 | 11:45 PM
Whatsrt4's Avatar
Whatsrt4
A mtx throttle body can be bored out to 55 mm for about $75.00 shiped from ebay,and an atx tb will cost you about the same from a wrecker, and give you 52 mm. What I did was bought an auto tb, put it on my car and shiped off my stock one to be bored . When I got it back I sold the auto tb to someone who needed it. Each step was an inprovement. (quote]ORIGINAL: neon15
[/quote]
Old Aug 25, 2006 | 02:23 AM
das2123's Avatar
das2123
ORIGINAL: Whatsrt4
They are like $35 from the junkyard!
Old Aug 25, 2006 | 04:34 AM
95neonriceeater
i would never pay $75 for a TB that is only 3mm bigger...
id rather just save up and get the 55mm
Old Aug 27, 2006 | 12:40 AM
Whatsrt4's Avatar
Whatsrt4
Did I mention I re-sold the tb for what I paid for it.So I had an improvement with the auto tb,shiped off my stock one.got it back, put on the 55mm tb for an even better responce.I then sold the auto tb to a friend..I also ported and polished my alluminium intake By the way that is Canadian $$ So in the end I got 6mm improvement in air flow for $68.00 US.and some elbow grease.My guess is about $10 per hp.I think thats a great deal!!!
ORIGINAL: 95neonriceeater
