cam gears???
Old Aug 26, 2006 | 10:23 AM
spudsterier's Avatar
spudsterier
Default RE: cam gears???
huh???
Old Aug 26, 2006 | 11:08 AM
casper's Avatar
casper
ORIGINAL: spudsterier
huh???
SOHC and DOHC pulleys are different, just agreeing
Old Aug 26, 2006 | 02:32 PM
spudsterier
oic
Old Aug 26, 2006 | 02:45 PM
ScrapYurImport's Avatar
ScrapYurImport
what is the advantage of this.
Old Aug 26, 2006 | 08:19 PM
das2123's Avatar
das2123
ORIGINAL: ScrapYurImport
If you are referring to the cam gear, then it's great for tuning and engine with an aftermarket cam. You can retard or advcance timing as needed.
Old Aug 28, 2006 | 01:39 AM
streetbikr600's Avatar
streetbikr600
hey i have a question for you guys with a stock cam but with a mopar pcm is it ok to advance the timeing with the cam gear or because of the pcm no like this for an example i advane the timeing 3 degress the pcm already advanceit by 2 so does that mean its advanced by 5. do you guys kinda know what im trying to say here
Old Aug 28, 2006 | 12:22 PM
das2123's Avatar
das2123
Wow, this cam gear sold for $81 brand new!
Old Aug 28, 2006 | 05:58 PM
jdub396's Avatar
jdub396
I'm not exactly sure what these things do, but I'm assuming the cam gear advances/retards your cam timing, where your programmer will adjust your spark timing.... Correct me if I'm wrong!!!
