difference of udp
Old Aug 25, 2006 | 06:04 PM
95neonriceeater's Avatar
95neonriceeater
Default difference of udp
so how come all of the underdrive pulleys on ebay are "three spoke" and not solid?
is that part of the weight reduction?
and didnt you guys say not to get anything from dynasty? cause those are the cheapest UDPs
Old Aug 25, 2006 | 06:12 PM
95neonriceeater
Default RE: difference of udp
whats the difference between the v-belt and serpentine?
one of the pulleys says you have to change the v-belt to serpentine
Old Aug 25, 2006 | 07:23 PM
spudsterier's Avatar
spudsterier
v belt is what your power stering and s/c are and serpintine is the alternator belt(flat belt)
Old Aug 25, 2006 | 07:25 PM
das2123's Avatar
das2123
Yes, it's part of weight reduction.
I think Dynasty had bad customer service.
Which one says you have to change belts? You have 1 serpentine belt already that runs around the A/C comp, P/S pulley and UDP and a V belt that runs from the UDP to the alternator.
spudsterier
your backwards das....
Old Aug 25, 2006 | 07:27 PM
das2123's Avatar
das2123
ORIGINAL: spudsterier
The serpentine is the V-belt?
Old Aug 25, 2006 | 07:29 PM
spudsterier
the serpintine is the flat one that runs the alt.
v-belt is the v shaped belt that runs the p.s. and a/c
Old Aug 25, 2006 | 07:37 PM
das2123's Avatar
das2123
My bad...it's been awhile since I changed the belts and since I don't run A/C or P/S, I guess I forgot [8D]
Old Aug 25, 2006 | 07:38 PM
spudsterier
yeah it is your bad
Old Aug 25, 2006 | 07:44 PM
das2123's Avatar
das2123
yeah it is your bad
But it's my freed up HP that I enjoy!!!!!
