Header
Old Aug 26, 2006 | 07:43 PM
vipper14's Avatar
vipper14
Default Header
Anyone have a step by step install right up for a 99 neon R/T?? basically the easist way to remove the alternator braket???
Old Aug 26, 2006 | 08:34 PM
das2123's Avatar
das2123
Default RE: Header
You don't have to do anything to the alternator bracket to remove the exhaust manifold or install the header.
Removal:
1)Remove air cleaner assembly and bracket
2)remove manifold heat shield
3)remove O2 sensor
4)remove exhaust pipe from manifold
5)remove 8 exhaust bolts.
Install:
1)clean off old gasket material and install new gasket
2)set exhaust manifold and gasket in place. Apply Loctite 271 or equivalent to fasteners and tighten to 23 N·m (200 in. lbs.) starting at center and progressing outward in both directions. Repeat this procedure until all fasteners are at specified torque.
(3) Install exhaust manifold heat shield.
(4) Connect upstream heated oxygen sensor connector.
(5) Install air cleaner bracket and assembly.
(6) Attach exhaust pipe and tighten fasteners to 28 N·m (250 in. lbs.)
Old Aug 26, 2006 | 11:24 PM
spudsterier's Avatar
spudsterier
Default RE: Header
you do need to remove the alt. bracket because one of the manifold bolts is right behind it.....i have yet to find a way to get to the bolt without removing the bracket....unless you wanna spend alot of time with a wrench
once the alternator is removed.....there are 2 small bolts ontop of the bracket that hold the little splash shield on the bractet and then there are 2 bolts on the under side of the bracket that take it off
Old Aug 27, 2006 | 12:09 AM
Whatsrt4's Avatar
Whatsrt4
Default RE: Header
I found it easier to remove alt also,unless you are a contorsionest,with knuckles to spare.[:@]
Old Aug 27, 2006 | 02:41 AM
casper's Avatar
casper
Default RE: Header
why do you need to remove the alt bracket to do the header? I had plenty of room to do mine without removing it.
Old Aug 27, 2006 | 04:03 AM
das2123's Avatar
das2123
Default RE: Header
ORIGINAL: casper
That's what I was wondering also?
Old Aug 27, 2006 | 04:21 AM
spudsterier
Default RE: Header
i was just thinkin of sumthing....dohc or sohc?????
i think the bolt pattern for the manifold is different for each.....on my dohc i have always had to remove the alt. bracket and could never find a way to do otherwise.....unless like alredy stated...
Old Aug 27, 2006 | 12:26 PM
das2123's Avatar
das2123
Default RE: Header
My instructions are for a SOHC.
Old Aug 27, 2006 | 05:22 PM
spudsterier
Default RE: Header
hmmm...i was just checking out haynes and it doesnt say anything about the alt. bracket either.......im goin to the garage here in a bit and i will check it out on the motors i have there...
