question and a lesson
Old Aug 27, 2006 | 05:30 AM
95neonriceeater's Avatar
95neonriceeater
Default question and a lesson
i put my short shifter in......
but my radio isn't working now since i reconnected the battery......
i changed the side fuse and it didnt change anything
so is it hte fuse behind the head unit?
how do i get behind it to change it?
and is it the same size as the one on the side?
my lesson...
i went out to race my friends to see how much faster hteir cars were...
later 1st gen dohc neon-aem intake, 52mm tb, magna flow exhaust, b&m short shifter
90's buick regal- supercharged with over 220hp
me with my sohc with a muffer and short shifter
i lost all 3 times
the first time becuase i didnt know we were launching
the second time, when i shifted to 3rd, the rpms went all the way down to around 45...?
then the third time i was about a half car lengths behind the dohc WHEN MY SRT-4 SHIFT **** POPED OFF GOIN INTO SECOND!
i think the third time i would have gotten 2nd...if it didnt **** up
we did it all 3 time at the same time in a wide empty road out by the storage buidings for safeway and stuff
the dohc won all 3 times
but he and i knew that if i put my tb and cai, it would have been a better race
so atleast i know the limits for my stock neon with the better air flow
here comes the mods...
and more wins...
Old Aug 27, 2006 | 12:40 PM
das2123's Avatar
das2123
Default RE: question and a lesson
The cai and TB will help, but try getting a Mopar PCM also.
Why not get a Pacesetter header on there while you're at it? They are cheap enough and work great for the SOHC.
Old Aug 27, 2006 | 05:49 PM
neoncrazy101's Avatar
neoncrazy101
ORIGINAL: das2123
i thought Pacesetter wasn't all that good of a company for the Neons?
Old Aug 27, 2006 | 08:29 PM
spudsterier's Avatar
spudsterier
its just cheap.....however the pacesetter has better gains on a sohc then on a dohc
Old Aug 27, 2006 | 08:41 PM
das2123's Avatar
das2123
ORIGINAL: neoncrazy101
ORIGINAL: das2123
The cat-back exhaust isn't, but the header is for SOHC neons.
Old Aug 28, 2006 | 04:32 AM
95neonriceeater
how much is the header?
and where can i get it? moderperformance.com?
Old Aug 28, 2006 | 06:21 AM
95neonriceeater
with all these upgrades i worry about passing smog...
and....
how much would it cost for a shop to put the header on for me?
Old Aug 28, 2006 | 09:30 AM
spudsterier
hard to say...depends on where you go and whats around you....id say, anywhere from $1.00-$1000.00
Old Aug 28, 2006 | 12:00 PM
das2123's Avatar
das2123
ORIGINAL: 95neonriceeater
$130 from Modern performance
Why, I have them all and pass just fine!!!
ORIGINAL: 95neonriceeater.
Shouldn't take longer than an hour maybe two, so see what the labor rate is. It's super easy to install the header though.
Old Aug 28, 2006 | 05:28 PM
95neonriceeater
do you have to take apart half the engine?
or just get underneath and take the header off of the engine and exhaust piping?
